Combined transition and turns - Printable Version +- Forums (http://warbirdsgscom.fatcow.com/forum) +-- Forum: My Category (/forumdisplay.php?fid=1) +--- Forum: Rules Questions (/forumdisplay.php?fid=4) +--- Thread: Combined transition and turns (/showthread.php?tid=36) |
Combined transition and turns - zco2007 - 07-02-2014 01:43 PM Is it possible to combine transitions and turns at diferent rates?. For example, I have a plane, banked 60R and I want to make a +3G transition and a +5G turn at the same time to maximiize performance. Is it possible? How to post it?. Used to the FW system I'm still a bit confused on how to state the transitions as they are not explicted anywhere, only by the initial / final plane attitude. Thanks Pablo RE: Combined transition and turns - admin - 07-03-2014 06:39 AM Hi Pablo, Yes, you may combine turns and transitions that have different G-Loading. In your case you are banked at R60u and in the basic rules are limited to facing changes (turns ;-) up to +5 G and transitions of +3G. Below is a move from a play test game, I would note any transitions in the Max G line with the G used and if it was a pull or push. Cheers, Steve 1518-SW / 6950 / 5.8(0.7) / 15C / L60u / - - Throttle: Full Thrust: 11 Drag: 5 FP: 6.5 FP Move: 6 FP Carry: 0.5 Max G: 3 (+2G Pull) Starting Nose Angle: 15C Nose Arc Change: 1 C/D Arc: 30C Ending Nose Arc: 60C Alt. Change: 250 HFP: 5 VFP: 1 1H (Bank L 2/1) L90v 2H-1V (2Ga/2Ge 3/3) 30L 2H (3Ga/3Ge 2/2) 30L ET/DT – FD/TD/ND/MD/CD (11 + 0) - (5 + 2 + 0 + 0 + 9) = 11 - 16 = -5 = -0.5 1921-S / 7200 / 5.3(0.5) / 60C / L90v / - - RE: Combined transition and turns - zco2007 - 07-04-2014 03:03 AM Nice!. I guessed so but I was just looking for the place and notation for the maneuvers!. Thanks!. Pablo (07-03-2014 06:39 AM)admin Wrote: Hi Pablo, |
